Platform: J-body
Cavalier 2004 cooling fan stays on all the time
Old Nov 26, 2012 | 9:47 AM
Mike San's Avatar
Default Cavalier 2004 cooling fan stays on all the time
The cooling fan on my vehicle stays on even when is cold, any idea of what is wrong? I check the fuse box and all fuses are ok, wonder if the relay has anything to do with this issue.
Old Nov 26, 2012 | 2:10 PM
kevinkpk's Avatar
You can pluck the relay out see if it turns off the fan. If it does either something is turning on the relay, or the contacts are welded together.
Old Nov 26, 2012 | 2:36 PM
Mike San's Avatar
Thanks Kevin, I will try it
Old Nov 26, 2012 | 2:58 PM
Mike San's Avatar
Can this issue set a trouble code?, I have not checked it with the scanner
Old Nov 26, 2012 | 3:10 PM
kevinkpk's Avatar
Only thing I could think of is if the sensor is shorted, that would explain the fan on all the time, a code, I doubt it.
Old Dec 10, 2012 | 8:35 AM
Mike San's Avatar
Relay is not the issue, I removed it and the fan stop working.
Old Dec 29, 2012 | 10:48 AM
cleveland63b's Avatar
doesn't mean the relay isnt stuck in the closed position, swap it out or try tapping on it and see if the fan stops. You don't have the a/c or defrost running do you? Other wise theres a short somewhere in the circuit or your temp sensor is bad
usspapaw
Cruze
11
Mar 23, 2021 3:00 PM
deanguy
Cruze
236
Feb 25, 2020 12:05 PM
nemo15824
Cruze
Oct 15, 2014 3:22 PM
slinkeril
Jul 29, 2014 10:03 PM
jjw
Oct 16, 2012 9:09 PM
