Caliper Bolt is stuck halfway out
1997 Cavailer.
Trying to put brakes on it. The bottom bolt came out but the top bolt broke loose turned about 3 or 4 full turns and then jams. I am thinking of getting the 3/8" allen wrench socket for my impact wrench.
Should I?
Has anyone else seen this?
Should I?
you should try using pb penitrate u can find it at walmart in the automotive section, spray it on and work the bolt back and bringing it out little at a time. if that dont work then use the ipact and i sugest after you get it out use a tap and die set to fix the threads
avoyager
August 4th, 2013 1:00 PM
Chad Cratsenburg
Silverado & Fullsize Pick-ups
October 15th, 2012 4:57 PM
blazer-man95
November 7th, 2010 7:16 AM
