S-10 & Blazer 1982-2005
How d you convert OEM single piston caliper to later model OEM dual piston caliper
Old Oct 21, 2010 | 8:28 AM
blazer-man95's Avatar
Default How d you convert OEM single piston caliper to later model OEM dual piston caliper
Morning Gents,
My 95 Blazer has been in my family since 2000, i inherited it after 2008 when i bought it back from my grandfather. Right Now its a cruiser w/ a modest exterior and a kicken system. Im not about speed but performance is a must. I currently have a strict budget with being deployed and all so I was wondering what would be needed to convert a single piston OEM brake caliper to a later model dual / floating OEM caliper. The current brakes are due to be replaced when i get back and just swapping the singles alone will help with braking quality two fold. However seeing as how i am no expert would they require a different mounting position or could I simply replace it. Anyways thanks for any help in advance and thanks for the time.
Old Nov 7, 2010 | 7:16 AM
EvansBlue's Avatar
You would need to change out the spindles as well as the calipers. You're probably looking at around $700 doing it yourself, and thats with a dirt cheap set of spindles.
TD83
11
Dec 18, 2019 2:30 PM
jj0996
Dec 18, 2013 10:27 AM
jthalbert
Apr 16, 2013 11:58 PM
PRNiner
Mar 26, 2013 7:30 PM
domano 68
Jan 28, 2013 11:22 AM
