Platform: J-body
Caliper Bolt is stuck halfway out
Old Nov 13, 2010 | 6:17 PM
dtsman's Avatar
Default Caliper Bolt is stuck halfway out
1997 Cavailer.
Trying to put brakes on it. The bottom bolt came out but the top bolt broke loose turned about 3 or 4 full turns and then jams. I am thinking of getting the 3/8" allen wrench socket for my impact wrench.
Should I?
Has anyone else seen this?
Old Nov 24, 2010 | 7:25 AM
mikeschopshop's Avatar
you should try using pb penitrate u can find it at walmart in the automotive section, spray it on and work the bolt back and bringing it out little at a time. if that dont work then use the ipact and i sugest after you get it out use a tap and die set to fix the threads
Typerod
Nov 20, 2014 4:53 PM
Chad Cratsenburg
Oct 15, 2012 4:57 PM
ronjon13
Mar 10, 2007 5:58 PM
