Platform: J-body
Chevy Cavalier Will NOT START
Old May 26th, 2013, 8:04 PM
ChevySteveD's Avatar
Default Chevy Cavalier Will NOT START
I've been to hell and back with this car working on it. It's a Chevy Cavalier 2.2L Motor, Has no spark, and No fuel pump Neither are starting, Anti-theft Light is on, and Check Engine light Along with ETS light, Has little bit of Oil. Replaced Crank Shaft Sensor, Plug Wires, Ignition and Key Cyllinder.
This is my only car i'm 19 and need it for my kid and girlfriend. I cannot afford to take it to the shop. I am really in dire need of some assistance.
Old May 27th, 2013, 10:35 AM
The security light on may be the issue...
I'd try the simplest first, try disconnecting the battery for about 10 min, hook it back up and give it a try...
What year model is it?
Old May 27th, 2013, 3:28 PM
get the theft deterrant codes read and post the codes here along with the model year.
theft codes are stored in the bcm so you will need a full function scan tool.
Old May 29th, 2013, 9:30 AM
Default Nothing
I have an OBD2 Scanner and got nothing the year is 1997 Chevy Cavalier We parked it out back 2 summers ago came to start it and move it to the front and the battery was dead, we replaced the battery when all this went on, since its been out there all we have done is replaced the stereo. No codes or dtcs
Old May 30th, 2013, 6:55 AM
what brand of scan tool. A code reader will not access body codes. If the theft deterrant light is on; you have theft codes set.
Xerklite
April 27th, 2013 9:14 AM
Nikki rogers
April 3rd, 2012 1:24 PM
xtrmsnd
December 31st, 2008 7:52 AM
Sunshyne276
July 19th, 2008 9:04 AM
atomheartmother
June 29th, 2008 9:41 AM
Quick Reply: Chevy Cavalier Will NOT START
