Folding down rear seats in a g20
Old May 25th, 2016, 9:37 AM
Emitchellll's Avatar
Default Folding down rear seats in a g20
So in my 1990 g20 van, there is an electric motor to fold down the rear seats into a bed. However recently, it stopped working. Is there a way to put these seats down manually or will I have to replace the switch or the motor? I would really like to be able to just put them down on my own.
Old May 25th, 2016, 10:04 AM
I really need help with this. I bought this van essentially to live in and for camping purposes and if I can't get the rear seats down, that would be a huge problem. Please help. Thanks!
Old May 29th, 2016, 10:24 AM
solwav's Avatar
What diagnosis has been done, the issue is probably simple have you tried to power the motor directly to 12V? Four things come to mind 1) the fuse is blown, 2) no power reaching the switch, 3) switch is faulty or 4) the electric motor is bad.
Old June 5th, 2016, 7:09 AM
awelder's Avatar
My express conversion van has one of these. I found four relays over by the rear a/c. I am assuming they are for the bed, so you might check for those. I have four as my bed slides front and back as well as reclines up and down. Good luck.
Old June 14th, 2016, 2:45 PM
JIMMYDRIVER1's Avatar
I agree with solwav. bench test it first. Salvage yards might have some used stuff in a van that's compatible. Otherwise some weekend engineering and you can make it work manually. I got a fold down back seat in my 88 G20 that isn't motorized but it has a bar that runs head to toe under the cushion that makes it impossible to sleep or do anything else on.
Old October 30th, 2018, 4:20 PM
Jimbob85's Avatar
To actually answer the question. Yes. You can recline the back seat without the motor. You would have to detach the cables that recline it. Then you can just grab the back of the seat and pull it down.
Old October 31st, 2018, 2:57 PM
StanVan's Avatar
You just answered a two year old question.
Old December 6th, 2020, 5:51 AM
David Oliver's Avatar
so? It’s a good question. Others may be looking for answers besides the op.
Old September 9th, 2021, 12:51 PM
79 Truckster's Avatar
Your answer helped me in 2021. I appreciate you responding to a “2 year old question”
