How do I ensure I get the 100% aftermarket fuel pump?
Old January 16th, 2015, 9:29 PM
Mikesbaron's Avatar
Default How do I ensure I get the 100% aftermarket fuel pump?
1999 Chevy Express 3500
I don't want to spend $300 for a GM oem part. I want to get a Bosch or Delphi fuel pump assembly. But there are so many different options and numbers. When I pulled the rusted and disgusting pump out of my van it had a white circle sticker on top of the assembly that said: VAZ, and then had some numbers. I can't find any of these numbers matching cross reference numbers to these other pump assemblies.
Old January 17th, 2015, 2:06 AM
canucklehead's Avatar
I got a bosch on mine, but I just went with the part the shop ordered for me. I don't know why there are many part options unless deisel and gas are diff. Have you called a dealer parts counter?
Old January 17th, 2015, 3:46 AM
burhead1's Avatar
carter P74778M Fuel Pump & Strainer Set
0.000 1 98-02
Fuel Pump Module Assembly [ELECTRIC FUEL PUMP]
Exc CA Emissions; Exc leaded fuel; w/Fitting For Take Off Fuel Line
(7T6); w/o Pressure Sensor; w/Tag Code Marked VAZ; Exc Cutaway Van, 1 Per Veh
The Bosch # is 67364
Old January 17th, 2015, 1:04 PM
Mikesbaron's Avatar
What's the rep of Carter fuel pumps? I've never heard of them.
Here are the codes on mine.
mangomanj
August 17th, 2014 9:51 PM
BRB
Silverado & Fullsize Pick-ups
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
darrendwilson
August 10th, 2010 5:23 PM
Quick Reply: How do I ensure I get the 100% aftermarket fuel pump?
