still stumped timing or ?
Old Jul 27, 2012 | 8:27 PM
jnaas2's Avatar
Default still stumped timing or ?
1996 gmc/g3500/5.7 tbi still cant get rid of knock, engine idles great but put it in drive and there is no power and the engine starts knocking. Talked to a mechanic and he said there is a crankshaft position sensor on it but I looked the engine over from top to bottom and there isnt one. This engine is in a used ryder truck that the did modifications to, any body got any ideas
Old Jul 30, 2012 | 10:04 PM
jnaas2's Avatar
Finally figured out that the vin number says its a 96 but actually its a 95 motor, Put a timing light on it and disconnected the brown wire with black stripe, which was at the distributor, and the timing went from 8 degrees advance to 0 degrees advance. But when you increase rpm the timing advances 4-6 degrees, Is this a distributor issue or timing chain, the timing doesnt jump around it stays rock steady just advances a little which would explain why there is no power its advancing to far and causing the engine to knock and lose of power
Old Jul 30, 2012 | 10:14 PM
kevinkpk's Avatar
Don't disconnect anything. Check the vacuum advance at idle, should be around 8*btdc. You should have generally 30* mechanical advance at about 3000 rpm.
Old Jul 30, 2012 | 11:05 PM
jnaas2's Avatar
The advance on this engine is controlled by the computer, because of all the stuff in the way I cant see how far its actually advancing
jmms
HHR
Apr 17, 2015 4:22 AM
Sevens
Jan 29, 2009 10:06 AM
kirah825
Dec 29, 2008 6:52 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
FreakOut420
Apr 22, 2006 4:18 PM
