1994 Chevy Blazer K
1994 Chevy Blazer K
I have two chronic problems with my Blazer.
1. When I press on the accelerator, i get an initial jump, but the engined then boggs for a second before resumingnormalacceleration.
2. I have plugs that fowl about every 6 months.
I would love your input as I am no mechanic. Thanks.
-Dave
-Dave
RE: 1994 Chevy Blazer K
We are talking K5 blazer arent we?
You can replace the catalytic converter to fix a problem with that.
Flooding problems will correct themselves most of the time, but if it doesn't you can adjust the choke.
ORIGINAL: EuroGoldLS
Never had to do it man. It may not be the cat at all. It may be something as simple astiming. Its hard to tele-diagnose that problem.
Next time you take a fouled plug out, take a close-up picture of the end of it before you clean it. It can be really helpful in finding out what the problem is.
doesnt sound like the cat but if u do have problems with it take it off and punch a hole through it from one end to the other. it sounds like a fuel problem to me but that shouldn't foul the plugs try using a hotter plug and see what it dose
Ride of the Month
May 2009
Ride of the Month
May 2009
I assume it has TBI
Sounds to me like you should check the timing, may be retarded slightly and also if you know someone with a scanner see if the tps is working ok
