1994 Chevy Blazer K
Old Feb 20, 2008 | 3:52 PM
habamock's Avatar
Default 1994 Chevy Blazer K
I have two chronic problems with my Blazer.
1. When I press on the accelerator, i get an initial jump, but the engined then boggs for a second before resumingnormalacceleration.
2. I have plugs that fowl about every 6 months.
I would love your input as I am no mechanic. Thanks.
-Dave
Old Feb 20, 2008 | 4:25 PM
EvansBlue's Avatar
Default RE: 1994 Chevy Blazer K
Sounds like its running rich. You could possibly have a clogged cat converter.
Old Feb 20, 2008 | 4:31 PM
habamock's Avatar
ORIGINAL: EuroGoldLS
How do I fix it?
Old Feb 20, 2008 | 4:49 PM
EvansBlue's Avatar
We are talking K5 blazer arent we?
You can replace the catalytic converter to fix a problem with that.
Flooding problems will correct themselves most of the time, but if it doesn't you can adjust the choke.
Old Feb 20, 2008 | 7:43 PM
habamock's Avatar
Indeed it is a K5. Is there any way to clean out the existing one? I don't have much money to play with.
Old Feb 20, 2008 | 7:52 PM
EvansBlue's Avatar
Never had to do it man. It may not be the cat at all. It may be something as simple astiming. Its hard to tele-diagnose that problem.
Next time you take a fouled plug out, take a close-up picture of the end of it before you clean it. It can be really helpful in finding out what the problem is.
Old Feb 21, 2008 | 11:16 AM
habamock's Avatar
I would love to hear some other opinions. Thanks.
Old Feb 21, 2008 | 12:32 PM
DAVID L. PAUL's Avatar
doesnt sound like the cat but if u do have problems with it take it off and punch a hole through it from one end to the other. it sounds like a fuel problem to me but that shouldn't foul the plugs try using a hotter plug and see what it dose
Old Feb 21, 2008 | 1:12 PM
EvansBlue's Avatar
what plugs do you use? If they are Champion or NGKplugs, throw them in the garbage and get some ACDelco or Bosch plugs
Old Feb 21, 2008 | 1:15 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I assume it has TBI
Sounds to me like you should check the timing, may be retarded slightly and also if you know someone with a scanner see if the tps is working ok
