Notices
8.1 Lower Head Bolts Leaking
Old May 17th, 2009, 12:18 PM
SDFever's Avatar
Default 8.1 Lower Head Bolts Leaking
Hi,
I have an 03 496 8.1 engine. Once you take the heads off and replace it is seemingly impossible to get a couple of the "lower" head bolts to stop leaking antifreeze... Drives me flippin' nutz at it sits in my boat with an all white engine compartment.
1. It does NOT leak with a pressure tester set at 16LBS over night.
2. I've used the GM brand brown sealant (seems like good sfuff).
3. Tried Permatex
4. Still using fresh Dexcool
Only leaks usually at higher rpms. Tried heavy coating of sealant on all threads, shank, and back side of hex part of bolts. Put sealant on both sides of stainless washer. Put some around the lip of the hole itself. Had it apart 4 times. This simple leak has out smarted me.
Jason@pacifictradesplus.com
760.522.0202
Many thanks to anyone who wants to hep me. If you're around San Diego Bay I'd be happy to take your for a fun ride any weekend.
Old May 17th, 2009, 7:16 PM
Professional Mechanic
MDTAHOE's Avatar
What kind of boat do you have? I have a 2003 stingray 230sx with a 8.1 (496) in it.
Old May 18th, 2009, 10:34 AM
SDFever's Avatar
27 Fountain
DOBERDEWD
December 11th, 2011 11:35 PM
chevyguy777
October 28th, 2011 5:02 PM
knucklebust
Silverado & Fullsize Pick-ups
June 12th, 2010 7:21 PM
SDFever
May 17th, 2009 12:14 PM
Quick Reply: 8.1 Lower Head Bolts Leaking
