Notices
Old July 22nd, 2015, 10:59 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
can I add an inline fuel pump instead of replacing the pump in the tank?
Old December 15th, 2007, 6:08 PM
  #11
22charlie's Avatar
Default RE: can I add an inline fuel pump instead of replacing the pump in the tank?
I don't know why the pump didn't last. Cutting the whole sounds good. I wonder if it could be done while the tank is in place?
Old December 16th, 2007, 8:50 AM
  #12
Dirtsurfer's Avatar
Absolutely, I put a welding blanket over the tank and used a cut-off wheel by 3M.It was too expensive for a hole saw that big. Make sure there's nothing in the way (fuel/brake lines,wire, reinforcements welded to the floor) before starting.
Old December 16th, 2007, 11:44 AM
  #13
cplthomas's Avatar
cutting what hole? Or are you refering to deleting the pump?
Old December 16th, 2007, 1:05 PM
  #14
Dirtsurfer's Avatar
In the floor of the vehicle to access the stock in-tank pump from the top. I covered the hole with a larger piece of metal and some RTV. If not properly equipt, it may be best to have a local bodyshop do it, I'm sure you're farmiliar with all the lawyer blurb.
Old March 21st, 2013, 9:54 AM
  #15
Rusty Clayton's Avatar
Default inline vs in tank fuel pump replace ment
im thinking to offer a suggestion that if you need to replace the tank fuel pump while you have the tank out make a access port to the unit if possible for future problems@
ibtommy
November 24th, 2019 8:23 AM
TPM
July 1st, 2017 12:10 PM
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
Fuel Truck
February 14th, 2013 2:18 PM
81FLT
November 2nd, 2009 5:30 AM
Quick Reply: can I add an inline fuel pump instead of replacing the pump in the tank?
