Notices
Gasoline into a diesel engine
Old June 11th, 2006, 1:28 PM
96Suburban's Avatar
Default Gasoline into a diesel engine
Hi, Had about 12 gallons of diesel in the tank and wife wanted a coffee, stopped and thought I'd put some diesel in but put 4 gallons of gas by mistake. It is a 96 suburban with a 6.5 turbo diesel and a 42 gallon fuel tank. I never started it and had the truck towed back home. Any suggestions, can I just fill it with diesel and it will dilute it enough, drain out the 16 gallons that are in there, ?? Thanks in advance
Old June 11th, 2006, 4:13 PM
SLJ2137694's Avatar
Default RE: Gasoline into a diesel engine
A small percentage of gasoline can be useful in the winter time if your diesel fuel is starting to jell. I would have driven it to a diesel pump and filled the tank and not think a thing of it. I have driven a diesel with close to the same amount of gasoline in it and never noticed a differance.
Old June 24th, 2006, 11:02 PM
1ndhoppe's Avatar
I've seen diesel put in a gasoline engine, and it ran OK, it was put in 'cause the tractor ran out of gas, and it needed to get into a shed.
Take care and God bless,
1ND-hoppe
shawnvw
January 7th, 2022 9:12 AM
STRESSED412
April 15th, 2012 7:31 PM
cata123
Silverado & Fullsize Pick-ups
November 19th, 2009 10:12 AM
tGunter
July 20th, 2009 6:16 PM
Quick Reply: Gasoline into a diesel engine
