Newbie w/problem w/ heated seats in '08 impala
Hi I have a 2008 chevy impala with heated seats. They worked fine then on the way home we put them on .. and the light for the heated seats would go out. Hubby said passenger said was hot but the lights went out. Anyone have any ideas what happened or have this problem?
Thanks
sandy
Thanks
sandy
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> @jesien24, how are things going with your heated seats situation in your 2008 Impala?
Michelle, Chevrolet Customer Service
must have been a fluke thing.. working good now.. thanks
do you know if there is a problem with the brakes on the 08 impalas? My car has been to the dealer a few times for brakes. First time they cut the rotors( may 2010) in july they put new ones on. Then in Aug or Sept(2011) they had to put back brakes on and then it went back in for the same vibration of the wheel shaking.. so they cut the front rotors again.
on my 08 I found that the slides were freezing/binding causing vibration took them all apart cleaned them up and used some waterproof grease and have not had a problem for over a year now The left rear was the worst
