Replacing ignitin switch - 1999 Suburban
Anyone ever replaced the ignition switch in a suburban? How hard is it to replace it? Any tips would be great. Mine is a 1999 model.
Jeff
Jeff
Hope This Helps
Remove the steering column shrouds. Once the column is exposed, on the top of where the ignition lock is mounted there is a hole. Insert the key into the lock. Rotate the lock to the ON/Start position. Insert an allen wrench into the hole and pull on the lock cylinder.
jzkemler1
June 21st, 2013 9:54 PM
MyBowTieGuy
September 21st, 2011 1:12 PM
realbadchevy
Silverado & Fullsize Pick-ups
August 5th, 2011 4:15 PM
jeffwest5599
January 6th, 2008 7:33 AM
