Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Current Chevrolet Car Models > Impala
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read Used CarsGarageVendors TSB & Recalls
Search
Welcome to Chevrolet Forum - Chevy Enthusiasts Forums
2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
LinkBack Thread Tools
Old 09-26-2008, 08:44 AM
Default '06 Impala rear defogger not working
My rear defogger quit working in my '06 Impala. The owners manual only references the rear defogger relay in the fuse box under the hood. I checked it and verified it was good. When you push the button on the console air controls the light comes on like the rear defogger should be working but nothing else happens. Are there more fuses or relays I should be looking for?
Register today for free or log-in if already registered to remove this ad!
Old 09-26-2008, 01:07 PM
shawnvw's Avatar
Professional Mechanic
Default RE: '06 Impala rear defogger not working
check to make sure the tab isn't broken off the window, then use a test light hooked up to both tabs while the defrost is on and see if it lights up.
__________________
If you have a question, ask it in the forums. I will no longer be answering questions sent to my email.
Old 09-26-2008, 04:48 PM
sounds like someone prob wiped a little hard back there and broke a tab
Old 09-28-2008, 11:13 AM
After looking at it closerit does appear that the tab has come unglued from the window.
Thanks for the suggestions.
Is there a special adhesive I need to re-glue this back to the grid????? or can I use anything like a super glue?
Old 09-29-2008, 05:06 PM
you need to make sure that the wires remain connected- even those on the glass. if theres a break in the wires- it wont work.
auto parts have kits to repair the lines.
But youll know which one doesnt work cause the rest of the glass clears up, except the non workin one-
but sounds like your trouble is right at the connector area
Old 09-29-2008, 05:29 PM
shawnvw's Avatar
Take it to an auto glass place and see if they will even attempt to repair it. A lot of places will not touch it because the heat fromthe soldering gun can cause the glass to shatter. And it needs to be solder to have a reliable fix
__________________
Tags
08, 2007, back, chevy, defogger, defrost, glass, impala, properly, quit, rear, reglue, relay, tabs, working
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
