2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
'06 Impala rear defogger not working
Old Sep 26, 2008 | 8:44 AM
drockwell's Avatar
Default '06 Impala rear defogger not working
My rear defogger quit working in my '06 Impala. The owners manual only references the rear defogger relay in the fuse box under the hood. I checked it and verified it was good. When you push the button on the console air controls the light comes on like the rear defogger should be working but nothing else happens. Are there more fuses or relays I should be looking for?
Old Sep 26, 2008 | 1:07 PM
shawnvw's Avatar
Banned
Default RE: '06 Impala rear defogger not working
check to make sure the tab isn't broken off the window, then use a test light hooked up to both tabs while the defrost is on and see if it lights up.
Old Sep 26, 2008 | 4:48 PM
rbarrios's Avatar
sounds like someone prob wiped a little hard back there and broke a tab
Old Sep 28, 2008 | 11:13 AM
drockwell's Avatar
After looking at it closerit does appear that the tab has come unglued from the window.
Thanks for the suggestions.
Is there a special adhesive I need to re-glue this back to the grid????? or can I use anything like a super glue?
Old Sep 29, 2008 | 5:06 PM
rbarrios's Avatar
you need to make sure that the wires remain connected- even those on the glass. if theres a break in the wires- it wont work.
auto parts have kits to repair the lines.
But youll know which one doesnt work cause the rest of the glass clears up, except the non workin one-
but sounds like your trouble is right at the connector area
Old Sep 29, 2008 | 5:29 PM
shawnvw's Avatar
Banned
Take it to an auto glass place and see if they will even attempt to repair it. A lot of places will not touch it because the heat fromthe soldering gun can cause the glass to shatter. And it needs to be solder to have a reliable fix
BMoTahoe
Dec 4, 2012 6:01 AM
wile13
Feb 12, 2012 8:28 PM
merlinroad
Nov 6, 2008 6:48 PM
bobt
Dec 13, 2007 6:23 PM
