2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
A/C can't hold freon
Old Jul 15, 2011 | 2:36 AM
VCDRNY's Avatar
Unhappy A/C can't hold freon
Hi I'm a proud owner of a 2002 3.4 Chevy Impala, love my car but since last summer I been having problems with the A/C. I filled up the freon and it would only give me cold air for like a week. I put on a vacuum on it to check for leaks and its holding on the pressure so it doesn't seem to be a leak.
Some one told me they had a similar problem and it was a bad O ring when under vacuum it held fine but once it had pressure the other way it would leak. Some one else told me to check if the system had a filter that cost about 8 bucks. Does any one else have or had the same problem and if you did what was the solution?
Old Jul 16, 2011 | 2:41 PM
kevinkpk's Avatar
I'd suggest adding dyed refrigerant in the system, it SHOULD show where it is leaking. I had same issue with my 96 Lumina, dyed refrig didn't show up. Had to replace the compressor due to a squealing cluth bearing, turns out it was an O ring from the discharge line that was leaking. Got two problems solved at once.
Phillips211
Jun 12, 2015 11:15 AM
BAUSTIN
Aug 2, 2011 11:45 PM
jarrewdrett
Aug 5, 2009 7:38 AM
#1DEER1I
Jul 28, 2009 8:44 PM
Elmer Fudd
Aug 27, 2008 9:37 PM
