2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Blinking SRS 7 times then OFF. Normal?
Old December 21st, 2015, 1:58 AM
crawdad's Avatar
Default Blinking SRS 7 times then OFF. Normal?
Hi Everyone,
2003 Impala 3.4
I just replaced the multifunction switch and everything works but now when I start the car, the airbag light flashes seven times and turns off. So I guess it's ok but I don't remember if it did this before or if it was just steady for a few seconds and went out as it does in my other cars. I did remove the neg batt cable and 10A SRS fuse before beginning to work on it. Mitchell's says it should flash then go out after the replacement procedure but should it continue to do this? Thank you.
Old December 21st, 2015, 1:46 PM
normal operaton
the system runs a diagnostic check at key on, flashes 7 times, and if all checks pass the light goes out.
Old December 22nd, 2015, 10:40 AM
crawdad's Avatar
Ok, thanks. I just couldn't remember if it had always done that before the repair.
Old January 8th, 2016, 11:12 AM
LeoTheLion89's Avatar
I personally would of just left the SRS fuse out, safer in the long run
Old January 8th, 2016, 1:54 PM
I an interested in knowing the reasoning behind that statement.
the impala is not involved in the takada recall.
Old January 8th, 2016, 7:34 PM
cleveland63b's Avatar
umm what?
Old January 8th, 2016, 8:36 PM
U.Nanimous's Avatar
Originally Posted by cleveland63b
umm what?
Oh no...don't get him started on that, he put the whole story up on the other website.
the whole story
Old January 8th, 2016, 8:47 PM
ha... to funny.
I do feel like a good debate though
Old January 8th, 2016, 10:59 PM
ha... to funny.
Eh, Debates lead to unjust bans. Not starting one. Bad enough having no answers to one's questions, than being singled out when a difference of opinion occurs.
Not really sure the point of message boards, when they don't even give you a straight answer. Especially ImpalaForums, where rules are set but even the Moderators and Administrators don't follow them.
Old January 9th, 2016, 9:46 AM
name calling will get u banned. banned before yes?
You did not post a question. You made a statement that may of had some merit when airbags were first introduced 25 years ago. Engineers have addressed these issues and crash test data from both low and high speed collisions confirm this.
readers without knowledge of modern pps and dual stage system operation may take your post as fact. This is what I challenge.
You most certainly can have an opinion. Sometimes, you may even get a response on a public internet forum.
