Chevrolet Malibu
2006 Malibu SS, check engine light. Fan on after 10 seconds
Old Apr 27, 2012 | 7:14 AM
Soliex's Avatar
Default 2006 Malibu SS, check engine light. Fan on after 10 seconds
I was driving home from work and parked my car. I went to move it later in the afternoon and realized my check engine light is now on. About 10 seconds after starting the car the fan in the engine compartment kicks on full blast. I drove it to work this morning and I noticed my temp gauge wasent moving and was all the way down into the C range. My drive to work is less than 5 minutes so perhaps it wasent enough time to actually warm it up.
Any suggestions as to what this could be? Thank you all.
Old Apr 27, 2012 | 8:55 AM
malibumike's Avatar
I had the same issue with my 07 maxx lt i changed the thermostat and engine coolant temp sensor and it fixed the problem hope this helps
Mike
Old Apr 27, 2012 | 11:30 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Soliex,
Malibumike offers a great suggestion regarding the thermostat and temp sensor. That may fix the problem. I encourage you to have the vehicle inspected by a certified technician to be sure.
Please keep us posted.
Louis
GM Customer Service
pinduca
Cruze
16
Jul 10, 2021 8:50 AM
CZ0
Nov 16, 2011 7:28 AM
pjbizjak
Oct 27, 2011 11:14 AM
Sunni Siluvai Pichai
May 25, 2011 6:52 AM
