S-10 & Blazer 1982-2005
91 s10 VSS issues-
Old August 3rd, 2014, 12:22 AM
shortbus11396's Avatar
Default 91 s10 VSS issues-
Ok, so I've got as stated 91 s10 Tahoe 4.3 v6 2wd. speedometer, cruise, odometer, trip are all inop. I had another VSS sensor that was good in a junk trans, and swapped out with the one in the truck. This did not fix the issue, also I pulled the inst. cluster and swapped it out as well just in case the dash was bad, still no luck. I made sure that the sensor plug wasn't corroded/burnt terminals, all is well in that department. My brake light is also on, but I haven't checked my ABS speed sensors yet due to lack of time at this current moment. Can anyone help me on this problem, Is there another sensor or module that I need to look at and test to fix this problem?
Thanks
Jessica
xclusive
January 1st, 2011 3:38 PM
LHHEMS
Express & G-Series Vans
December 28th, 2007 7:27 AM
knute3
June 1st, 2007 12:45 PM
danfros
Avalanche
May 21st, 2007 2:46 PM
Rescue30
May 1st, 2007 10:34 AM
Quick Reply: 91 s10 VSS issues-
