VSS bypass switch?
Old May 25, 2007 | 10:47 AM
knute3's Avatar
Default VSS bypass switch?
I was wondering if one could put a switch on the VSS wire so that I could flip it off while at speed in order to be able to input NAV data without having to stop? If I do, then flip the switch back on, how long would it take for everything to begin working normally?
Old May 25, 2007 | 12:19 PM
cabin232's Avatar
Default RE: VSS bypass switch?
Installing the lockpick/unlockharnesswill achieve the sameresult with much less effort!
Old May 30, 2007 | 11:25 AM
knute3's Avatar
I realize that, but dont want to spend the money for a lockpick because I really dont use the Nav all that much, but a cheap little switch would allow me to use it on the road in the few instances that a passenger could enter data while driving.
Anyone know how long it would take for all the Nav stuff to go back to normal if I "switched" the VSS wire off and then back on?
Thanks
Bill
Old May 30, 2007 | 11:38 AM
ZX1100F1's Avatar
Should work but will trigger a DTC. The nav unit will either go back to normal operation immediately or on the next key cycle.
Old May 31, 2007 | 5:17 PM
knute3's Avatar
What is a DTC? And how long would it take to get to the next key cycle?
Thanks
Bill
Old May 31, 2007 | 5:21 PM
ZX1100F1's Avatar
DTC = diagnostic trouble code (warning light on instrument panel).
The next key cycle is when you shut the truck off and restart it.
Old Jun 1, 2007 | 11:29 AM
knute3's Avatar
Lets say it trows a code. Will it reset itself when the VSS is reestablished or is it something a dealer will have to correct?
Thanks
Bill
Old Jun 1, 2007 | 12:45 PM
ZX1100F1's Avatar
Light will stay on for a while or next key cycle and then the problem will be stored in memory for a while but poses no other problem for you.
Judging from your concern my advice is don't monkey with it, get the Lock Pick.
SabrToothSqrl
May 17, 2015 2:15 PM
vee
Astro
May 16, 2013 7:46 PM
xclusive
Jan 1, 2011 3:38 PM
mirage00
Oct 21, 2010 10:32 AM
SabrToothSqrl
Oct 27, 2009 8:04 AM
