S-10 & Blazer 1982-2005
backfires
Old May 4, 2011 | 9:19 AM
87s10dragproject's Avatar
Default backfires
i got a 87 s-10 pickup with a 2.8 v6 in it. i am having an issue with it not wanting to start and when it does it backfires alot and it has recently been shooting flames out the exaust. i have replaced the exaust from muffeler back there is new plugs and wires and distribution cap. im in a loss cause this is currently my daily driver soon to be drag project
can someone help
Old May 31, 2011 | 7:45 PM
lynnboy021's Avatar
backfire is when your not fireing at the right time. you should check for codes and do a fuel and compression test first and let us know.
Old Jun 26, 2011 | 8:06 PM
cdf912's Avatar
There are two types of backfire...in the engine and in the exhaust. If its in the exhaust then that means you are running rich and the unburned fuel ignites in the hot exhaust, sometimes shooting out a flame. So determine why unburned fuel is getting in the exhaust. Check the EGR valve, and the valve timing as well as all Plugs are firing normally.
gumbute
Feb 29, 2020 11:26 AM
sirflipper
Jul 11, 2011 6:35 PM
newcaredoc
Feb 12, 2011 12:21 PM
irishcream
Apr 23, 2009 3:15 AM
dkerns2004
Apr 6, 2008 10:16 PM
