abs brake light
abs brake light
i have a 2001 s-10 blazer. the abs and brake light came on the other day. i checked the brake fluid resevoir and it was okay. the next time i started it up the light when off. what do i need to look for. thanks Bob
My 1999 Silverado has been doing that on and off for the past several years. It does it for a while then it won't do it for a long time. I heard it was the ABS sensors, so I cleaned them. Didn't help. I then replaced them, no luck. Now I live with it. The next step would be to replace the ABS control. You can try the sensors, maybe you will be lucky and it works for you.
kaptain howdie
December 16th, 2014 8:20 PM
Bulldog9539@gmail.com
September 4th, 2011 1:54 AM
beckya99
July 12th, 2011 12:29 PM
Deteoni
March 28th, 2009 1:39 PM
