S-10 & Blazer 1982-2005
Very bad transmission leak!
Old April 1st, 2013, 6:31 PM
Ar_lynn's Avatar
Default Very bad transmission leak!
My 98 s10 is leaking transmission fluid like no other. It started while I was on the expressway. The fluid was leaking onto my exhaust causing a lot of smoke and when I pulled over the remaining fluid leaked out. It looks like its leaking from the front seal. I've decided to remove it myself and hopefully fix the leaky seal.
I have no experience at all. I know that I need a transmission jack to remove it. I also have basic knowledge as to how the transmission and the torque converter fit together.
Does anyone have any advice? Are there other seals or parts I should replace while I have it out? And is there anything else that could cause a leak like that?
It's an automatic transmission, by the way. And I've only had it for about a month.
Old April 1st, 2013, 9:05 PM
Former Sponsor
go-part's Avatar
How to Troubleshoot a Chevy Transmission Leak | eHow.com
mdm6713
Silverado & Fullsize Pick-ups
December 30th, 2019 4:41 PM
mattycakes
October 15th, 2013 10:58 PM
Resto65
January 19th, 2009 11:07 AM
billyjoe72
October 21st, 2005 4:33 PM
Quick Reply: Very bad transmission leak!
