04 Suburban Dash Removal
Old Jan 26, 2008 | 12:14 PM
hdfxrusa's Avatar
Default 04 Suburban Dash Removal
Looking to find out how to remove the dash to replace the stock radio. Any pixs or how too's would be much appreciated!
I posted this also in the audio section but thought that I would get more help from this forum.
Thanks,
HDFXRUSA
Old Jan 28, 2008 | 11:16 AM
southern slammer's Avatar
Default RE: 04 Suburban Dash Removal
hi there,
the dash cover consist of a few screws and 2 push pins for the removal of the handbar on the passanger side. open your door on the side there are cover take them off u will see 2 screws undo them on both sides.take your air vents out on the passanger side with a flatblade screw driver nothing special just pull them out u have to reach inside there is a push pin located in there just push and pull bar outwards at the same timethis goes for both sides ok.remove your dash bezel by pull it outward there are no screws involved in removing it.When you look behind the bezel you just removed there are about 6 screws or 7mm nuts holding ur dash on ,just take em out and ur pretty much done.remove both pillars by prying them off and outwards.then u can pull forward on your dash cover to remove but dont pull too far you will have to undo the
[IMG]local://upfiles/8968/AC0D04C4ADFE4069BF5ACADB803D969F.jpg[/IMG]
Old Jan 28, 2008 | 11:20 AM
........undo the light sensors on the dash cover in the front by windshiled.here is a few pics i took for ya ok so its better to understand bu tit is quite simple to do really so dont stress it out ok.
[IMG]local://upfiles/8968/D08EA000460D43A5A2E9A248118223B2.jpg[/IMG]
Old Jan 28, 2008 | 4:40 PM
hdfxrusa's Avatar
ORIGINAL: southern slammer
Thanks for the info! I am sure it will not be a problem.
HDFXRUSA
Old Jan 31, 2008 | 12:06 PM
hopelesssinner's Avatar
hello, i am gonna replace radio in a 02 sub. do you have remove dash cover or just dash face to replace radio? jon
Old Jan 31, 2008 | 2:29 PM
hdfxrusa - you don't need to remove all that stuff to remove the radio.
turn the key on, put gear shifter all the way down, tilt steering wheel all the way down, and just pull off the panel srounding the radio, hvac controls and intrument cluster. then remove the3 7mm bolts to remove radio
hopeless - your dash is exactlythe same. The only difference in removing the radio is that yours is just clipped in.
Old Jan 31, 2008 | 6:11 PM
shawn, thanks for reply. will change it this weekend. hopelesssinner
Old Feb 1, 2008 | 9:52 AM
hdfxrusa's Avatar
[quote]ORIGINAL: shawnvw
Thanks shawnvw for the reply!
HDFXRUSA
Old Feb 3, 2008 | 4:33 PM
sorry wasnt sure if u were installin a indash tv or a regular din cd player.
Old Sep 13, 2009 | 11:52 AM
hayseed's Avatar
Question more question on dash cover removal?? help
hello i need to replace my ac vent actuators and believe they are hiding under the dash cover,, i read the post but was hoping to get some pics or additional info on how to remove the dash cover,,, i just dont want to snap anything or have rattles putting it back together
thanks
Mark Hubley
Nov 13, 2020 5:52 PM
Ugadawg
Jul 11, 2012 8:53 PM
Ronaldo
Apr 5, 2008 9:23 PM
