Platform: J-body
Headlight problem on '99 Cav
Old May 7, 2006 | 9:53 PM
jorgie5150's Avatar
Default Headlight problem on '99 Cav
I'm having a strange problem with my headlights on my '99 Cav. The driver side lamps work fine, but both lamps on the passenger side are dim all the time. I replaced the lamps, but the new ones are dim too. I checked the fuses, they are fine too. Switching between hi beams and low beams doesn't make a difference, the passenger side is dim all the time.
Any ideas? This is stumping me and my friends.
Old May 8, 2006 | 6:55 AM
Nomad76lj's Avatar
Default RE: Headlight problem on '99 Cav
you may have to replace the socket. its cheap and easy to try anyway.
Old May 8, 2006 | 11:24 AM
SLJ2137694's Avatar
Check the electrical ground circuit for a good connection.
Old May 9, 2006 | 6:51 PM
jorgie5150's Avatar
ORIGINAL: Nomad76lj
Do you mean the sockets the lamps plug into?
ORIGINAL: SLJ2137694
Are the grounds for left and right headlights separate? If there is just one and its a problem with the ground connection, wouldn't both the left and right side have problems?
Old May 10, 2006 | 6:56 AM
Nomad76lj's Avatar
i think both sides have there own ground. unplug the light and look for the black wire thats bolted to the car near the rad .
garyv990
Feb 11, 2015 9:52 PM
moab
Jul 30, 2011 2:07 PM
Badeshlesh
Aug 18, 2008 9:38 AM
blacklabelcali
Mar 22, 2007 11:12 AM
Schlickster
Jul 25, 2006 2:36 PM
