Platform: J-body
Problem with 1998 cav sedan
Old Aug 14, 2008 | 9:27 AM
Badeshlesh's Avatar
Default Problem with 1998 cav sedan
I have been experiencing a problem with my 1998 cavalier sedan for about a week, but now it has become really noticeable. Whenever I accelerate, my engine (or something) has begun to make a very annoying, almost like a high pitch whining sound. This happens whenever the engine is cold or has been running for a while. Any suggestions as to what it could be?
Old Aug 16, 2008 | 11:24 AM
GraveDigger's Avatar
Default RE: Problem with 1998 cav sedan
Is it a whine or more like a humming sound? Sometimes IAC valves will make a lower-pitched humming noise that I've heard referred to as "moosing". The PCM opens and closes that valve as needed to direct air around the throttle body to keep the engine from stalling due to lack of airflow from a closed throttle plate. If the IAC valve is dirty or damaged, it could be making that noise. Take the air cleaner hose off the throttle body and inspect the throttle plate area fordirt/carbon build up, and spray it out with throttle body cleaner if it's dirty. Don't start the engine until after it's had time to drain (an hour should do), or you could foul your injectors.
If you want to check the IAC valve, you can remove it from the engine and spray it out with carb cleaner to remove any deposits or dirt (carb cleaner evaporates). You'll need to get a new IAC valve gasket if you remove it though. You can also try to listen to it with a mechanic's stethoscope and see if the noise originates there.
Old Aug 17, 2008 | 10:46 PM
shawnvw's Avatar
Banned
Check the power steering fluid
Old Aug 18, 2008 | 9:38 AM
Badeshlesh's Avatar
It was the power steering fluid, I had a leak...gotta fix the pipe. thanks!
trunks9_us
Dec 8, 2012 1:21 PM
kkelly95
Jan 28, 2010 9:42 AM
98_cavy_cs
May 14, 2009 9:26 AM
blacklabelcali
Mar 22, 2007 11:12 AM
jorgie5150
May 10, 2006 6:56 AM
