Installing Running Boards - Is this easy?
Old Feb 23, 2008 | 10:20 AM
NorthWoodsDave's Avatar
Default Installing Running Boards - Is this easy?
We just purchased a 2007 Silverado 2500 HD Crew Cab. Now we want to install running boards.
Is this easy to do?
What's involved?
Any recommendations for what to look for in a running board or are they all pretty much the same in terms of quality?
Thanks, Dave
Old Feb 23, 2008 | 12:21 PM
northey87's Avatar
Default RE: Installing Running Boards - Is this easy?
Are you wanting "running boards" or nerf bars/step rails?
Old Feb 23, 2008 | 2:17 PM
Most of them willmount the same way as nerf bars. There are holes in the frame that the bolts go through.
Old Feb 23, 2008 | 5:48 PM
mdsheely's Avatar
I got the GM brand running boards. They were very easy to install. No holes to drill, very solid. Check these out.
http://www.gmpartsdirect.com/results...umber=17801890
Old Feb 23, 2008 | 9:00 PM
My preference would be nerf bars, but I won't rule out running boards. I've been told Westin and Lund are good quality. Any brands I should consider and should I go with stainless steel?
Dave
Old Feb 24, 2008 | 12:37 AM
fireman526's Avatar
If you want running boards, personally I would get them from GM for quality and proper fitment. If you want the polished look of nerf bars, definatley go with stainless steel, they wont rust. Although cheaper, chrome plated bars will rust if you scratch them. No matter what you go with, their all easy to install, just like Eurogold said, there are holes already there for the bolts to go through. It helps if you have two sets of hands doing the project.
Old Feb 24, 2008 | 6:41 AM
Tatonka's Avatar
Hi,
I installed the GM 6" chrome tubular assists on my 2007 silverado 1500 a couple of months ago with my son (5 years old). Very easy to do and they came with all the required hardware. Now my son can climb up into the truck by himself ;-)
Old Nov 30, 2010 | 2:29 PM
extremus's Avatar
How have these boards held up?
Old Dec 1, 2010 | 10:31 AM
jvc350's Avatar
I have the GM 6" oval and they are great. Easy to clean and they stay shiny. If you can turn a wrench, then you can install these. All the holes are in place and the GM boards are solid.
thetahoe
Sep 22, 2024 5:09 PM
scott_mckinney
Mar 24, 2007 12:03 AM
gmarcucio
HHR
Dec 30, 2006 2:56 PM
biglg
Oct 13, 2006 7:15 PM
Top
Follow Us
