Uplander 2005-2009
Platform: U-Body
rear end rattle
Old Mar 14, 2008 | 6:07 AM
seawind3000's Avatar
Default rear end rattle
I have an 05 & an 07 uplander, both have developed a hard rattle in the rear. The axel bushings were replaced on both so we thought it was cured, ..... for about 20 miles and back again. The " microphone check" can't find anything. Anyone have the same prob?? And why do the headlights and dash lights flicker when I speed up slightly??
Thanks, Mike
Old Mar 14, 2008 | 6:05 PM
jsm's Avatar
jsm
Default RE: rear end rattle
Had this problem on an 03 Venture. Was driving me crazy. Turned out to be the parking brake cable adjuster bracket near middle of rear axle was rattling on the axle when going over bumps. With time the cable gets some slack in it . I put a piece of that foam plumbing insulation for copper pipes over the parking brake bracket, and held in place with a couple of nylon ties and/or some electrical tape wrapped around it. Worked for me. No more rattle.
Cable can rattle against axle even if you do adjust the slack out of it.
Old Aug 13, 2008 | 12:30 PM
Papa Bear's Avatar
I developed a bad rattle in the rear of our '07 Uplander and it turned out that while washing the van I had dislodged that hard rubber seal that goes from the top of the rear lift-gate to the roof and that 3 foot or so piece of rubber fell down into the trough and was rattling every time I hit a bump. Re-installed the rubber seal and the rattle was gone. Hope this helps.
Papa Bear
rsouri
Aug 6, 2020 8:34 PM
JustinL
Aug 23, 2014 12:54 PM
bs silverado
Jul 26, 2010 6:43 PM
Backyard
Apr 14, 2010 7:24 AM
julian734
Mar 10, 2007 11:31 AM
