2016 Camaro
Platform: F-Body & Zeta.
swapping motors
Old Jun 28, 2006 | 9:29 PM
gmcjr's Avatar
Default swapping motors
i just boug5h6t a 92 carmo 25th av. h6ow h6ard is it to put a brand new 30g5 in it asnd is th6ere any known problems i sh6ould expect?
Old Jun 29, 2006 | 11:01 AM
Nomad76lj's Avatar
Default RE: swapping motors
should be able to swap it stait in is your car a 6 or 8 cylender now?
Old Aug 30, 2006 | 11:20 PM
uncle bill's Avatar
The swap is pretty simple. If You and just changing V-8 for V-8, make sure You use all the same sensors and all the computer wiring etc. If its a V-6 to V-8 swap., It's a bit more complicated. Since it's a 25th anniversary, It's probably a factory 305. If not, then make sure You use all the V-8 sensors, computer, exhaust etc or it won't start and run right.
1953drtelco
Dec 27, 2013 12:14 PM
Daspenorth
Mar 15, 2008 11:55 PM
djpred
Dec 5, 2007 11:07 AM
