swapping motors
The swap is pretty simple. If You and just changing V-8 for V-8, make sure You use all the same sensors and all the computer wiring etc. If its a V-6 to V-8 swap., It's a bit more complicated. Since it's a 25th anniversary, It's probably a factory 305. If not, then make sure You use all the V-8 sensors, computer, exhaust etc or it won't start and run right.
Daspenorth
Mar 15, 2008 11:55 PM
