Chevrolet Avalanche
Platform: GMT 805 & 900
factory remote starter short range
Old Nov 11, 2008 | 10:29 PM
cyclonebk's Avatar
Default factory remote starter short range
I have seen posts about the Chevy factory remote starters having short range(mine included). There are posts telling about doubling the range simply by locating the antennae wire, pulling it away from a wire harness, and exposingtheend.Does anyone know wherethis wire is located in the2007 Avalanche? All of the threads I have read refer to where it is in a Tahoe. This sure seems like a better way than buying an aftermarket extender.
Old Nov 12, 2008 | 9:03 PM
charlie pachanga's Avatar
Default RE: factory remote starter short range
This vehicle uses a coax cable to the antenna. Antenna location is above rear window behind center plastic panel by roof.
Old Nov 12, 2008 | 10:00 PM
cyclonebk's Avatar
Are you familiar with the procedure that has been posted on the Tahoes? If so do you think that it will work on the Avalanche. How do I get the plastic panel off? the air bags are behind it. Thanks
jlenkows
Feb 9, 2016 6:18 PM
bigjohn12
Jun 3, 2015 11:37 AM
Impowa
Oct 2, 2010 1:05 AM
mobilemodding
Dec 7, 2008 11:39 PM
speedtactics
Feb 18, 2008 10:28 AM
