Uplander 2005-2009
Platform: U-Body
Change 07 Uplander plugs.
Old Apr 12, 2009 | 12:31 PM
arminkropp's Avatar
Default Change 07 Uplander plugs.
I was Wondering what the best way to get at the rear plugs on an 07 uplander is. I searched the forum and all I could find in the archive is instructions for an 05. There you unbolt the top motor mounts and push the van backwards to make the engine "roll" forward. Will this work with the 3.9L in the 07?
Thanks
Old Apr 12, 2009 | 9:33 PM
I usually unbolt the upper engine mounts and pull the engine forward with a rope. I then secure it with a small cable that I keep in the toolbox, but a thick wire will work in a pinch.
That gives you fairly good access to the plugs on the back. You'll definately need a universal joint and a decently long extension to get your spark plug socket back there.
Old May 10, 2009 | 10:45 AM
riotz's Avatar
OK here's another probably stupid question regarding this; Can you just tilt the motor without having to say, disconnect the exhaust? Or is it possible to do it without having to?
My '06 at 128K (km) seriously needs new plugs and I sure don't want to pay to have it done when I can do it myself.
Old May 10, 2009 | 11:19 AM
Yeah. The exhaust has enough play to allow you to tilt it.
Old May 11, 2009 | 2:55 PM
riotz's Avatar
Excellent, thanks
Old Jan 23, 2011 | 12:48 PM
SLberg's Avatar
i have a chevy venture i assume same procedure does any thing else need to be disconnected ?
Old Jan 23, 2011 | 3:27 PM
Papa Bear's Avatar
What year and engine ??
Old Mar 17, 2011 | 2:45 PM
991500hd's Avatar
jeez I signed up on this site today to figure out how to change my spark plugs on my 06' And now I find out I have to "unblot my motor mounts??? This is awful. I like my 99 truck alot better!
Old Mar 19, 2011 | 8:00 AM
ice777's Avatar
If anyone is comparing prices;
On my 2005 Uplander, a month ago, I paid $183.00 Canadian to have the plugs changed [platinum plugs] at the Dealership in Alberta.
bizkit64
Nov 15, 2015 6:29 PM
High$
Mar 9, 2014 1:59 PM
mjpmin
Aug 18, 2013 7:13 PM
espy59lc
Apr 13, 2011 5:05 PM
dbrog28301
Colorado
May 21, 2007 9:48 PM
