Platform: Delta
Also Check out CobaltSS.net
Cobalt SS pioneer system
Old Apr 15, 2009 | 5:38 PM
Reidje's Avatar
Default Cobalt SS pioneer system
Im looking at installing an aftermarket system in my 05' ss. Just wondering what the rated watts on the pioneer speakers were, how to remove the rear speakers, and if id have to rewire the speakers to an aftermarket head unit.
Old Apr 15, 2009 | 6:22 PM
so you're adding an aftermarket head unit to a factory installed pioneer speaker system?
Just look for an integration module for your particular sound system. Should have a set of RCA's on it to plug into the head unit. should make the install a breeze.
Old Apr 18, 2009 | 11:54 AM
Reidje's Avatar
ive been looking around and all i can find is a harness that will retain the door chimes and acessory power but none that will use the factory installed amp
Old Apr 18, 2009 | 2:33 PM
buy that kit.....You are going to splice a set of RCA's into the speaker leads of the integration module, and then just plug them into the rear of the radio. That will send a low level audio signal to the amp, and the speaker will not be distorted.
Old Apr 19, 2009 | 1:18 PM
Reidje's Avatar
Okay, ill do that then. Thanks for all your help.
2l8iwn
Apr 1, 2011 12:15 PM
aslap
Cobalt
Nov 4, 2010 1:02 PM
Clay24
Jan 18, 2007 11:23 AM
