S-10 & Blazer 1982-2005
need help with 95 gmc sonoma and a 99 2.2 engine
Old May 24, 2009 | 1:06 PM
72gsbuick's Avatar
Default need help with 95 gmc sonoma and a 99 2.2 engine
i bought a 95 gmc sonoma that has a 1999 2.2 engine, had no coil, put in the coil, and noticed there is a knock sensor like next to the sensor that hooks up to the coil, that was unpluged, there is no connector that it so i have no way of hooking it up, so i was told that the 99 2.2 is a bit different in that of the sensor, when i start it up, it starts up fine, but lacks of power, and shakes bad almost as if it had a bad mount. trucks a 5 speed and does not have much power at all.. also noticed it sounds like a misfire of somekind, and i can hear rocker arm sound as if it wanted to shut off..anyone know what the problem is, is there a way the knock sensor could be affecting it, if so how can i by pass it..thanks in advance.
isrummell
Sep 22, 2013 9:46 AM
sandobar
May 14, 2013 6:26 PM
evilfireman
Dec 27, 2012 12:41 PM
aquaholic
Dec 14, 2008 7:58 AM
redneck 4 life
Mar 11, 2008 7:58 PM
