door open chime
Old Jul 8, 2009 | 8:18 PM
wopp's Avatar
Default door open chime
I do a lot of stop and go check stops in my line of work, I am very tired of the chime going nuts every time i hop out to do a check and leave my key in. How do i disable that chime??? Thanks wopp
2007 chevy silverado 4 x 4 3500 flat bed work truck, diesel engine automatic trany
Old Jul 8, 2009 | 8:26 PM
lukemoore646's Avatar
kinda vauge on the info, any more like year and model will help, but read the owners manual first, it might help
Old Jul 9, 2009 | 8:42 AM
shepdog25's Avatar
fade your speakers to the rear
Old Jul 9, 2009 | 10:17 AM
shepdog25's Avatar
sdrry, fading the speakers won't work. You have to disconnect the speaker in the driver side door
Old Jul 11, 2009 | 6:34 PM
your best bet would be to put your door pin switch on a toggle switch so you can turn it off when you don't feel like hearing the chime.....need to know if you have a classic pick-up or new body style before I can help any further
Old Jul 12, 2009 | 9:02 AM
wopp's Avatar
Default chime
my truck is a classic
Old Jul 12, 2009 | 1:19 PM
wffokker's Avatar
This might be an abvious one but if your vehicle is off pull the key out just a bit, this will kill the chime, youl have to remember to do it for a while but then it is just habit.
Old Jul 13, 2009 | 8:02 AM
wopp's Avatar
Default chime
I do a lot of night work with lights on engine off chime drives me nuts, in my 01 silverado a mechanic just unpluged a little black chime controler some where and it solved the problem, just though my 07 would have the same chime controler
Old Jul 13, 2009 | 4:34 PM
Chimes are built into the radio
if you have a base model truck(no windows\locks) you'll find a grey\black wire at the BCM, connector 4, pin B4.
If you have an uplevel truck(with windows\locks), you will find the grey\black wire in the drivers door at the door switches. It is in connector 2, pin 18.
Install a toggle switch on this wire, and when open, the computer will not know that the door is opened and will not produce a chime
89scottsdale
Aug 22, 2022 10:07 PM
xrayrep
Jun 21, 2014 4:59 PM
elsoso
May 21, 2013 9:43 PM
countrybea50
Traverse
Feb 15, 2012 1:08 PM
sketch222
Jun 18, 2009 8:18 PM
