Silverado 2004 5.3 Vortec
Old Jul 11, 2009 | 7:22 PM
John Boy's Avatar
Default Silverado 2004 5.3 Vortec
Anoying steering noise when turning left at low speeds. Driving me nuts. How can this be repaired permanently?
Thanks
Old Jul 11, 2009 | 8:06 PM
John Boy's Avatar
Whould a faulty intermediate steering column cause this problem? Or only the knocking?
Old Jul 11, 2009 | 8:42 PM
ukrkoz's Avatar
1. ISS does clunck at take off or rapid slow down, when front dives or jumps up. irrelevant to turns and not heard during regular driving.
2. CV joint? check boots
3. there was an STB on frame problems for some GM makes, with 4 WD, causing popping noise in tight turns in parking lots. applicable? left side only also.
Old Jul 11, 2009 | 8:45 PM
JKR1040's Avatar
I believe from 1999 to 2006 these trucks have that same noise from the steering column, even my truck makes that noise. Its a defect that was never fixed or explained at least to my knowledge.
Old Jul 18, 2009 | 6:03 PM
John Boy's Avatar
thanks for your feedback. i should have also stated that if i flush and replace steering fluid this annoying noise will stop ... for a couple months. would you still suspect the cv joint or boots?
Old Jul 19, 2009 | 12:11 AM
lukemoore646's Avatar
might try to describe the noise, is it a small clunking or more of a low pitched whining growl
Old Jul 19, 2009 | 11:50 AM
John Boy's Avatar
Sound is exactly the same as if it was low on steering fluid. And do not hear this annoying sound always. Does not impact steering. This truck is a dream with this one exception.
Old Jul 19, 2009 | 9:33 PM
what does the fluid look like when you flush it, also what do you use for fluid
Old Jul 19, 2009 | 10:58 PM
stevblev's Avatar
my dad has an 04 2wd
and he had his steering shaft replaced under warranty for making some type of noise
Old Jul 20, 2009 | 10:57 AM
Zral's Avatar
3. also, ext. cab 2wd 1500's. Mine was one of them.
