Oil pressure in 5.3L
Old Jul 23, 2009 | 6:21 PM
tsduke's Avatar
Default Oil pressure in 5.3L
What is the optimal oil pressure range for this motor?
My 2005 is as low as 30 on idle after it's warm. 50-60 if you get on it and run about 45 when cruising at 70mph.
Old Jul 23, 2009 | 6:28 PM
suzuki-guy's Avatar
That is normal once warmed up! Most trucks run 20 at idle and 40 at cruise. Mine runs 60 at cruise and 40 at idle but that's because I have a high volume oil pump.
Old Jul 23, 2009 | 6:36 PM
tsduke's Avatar
I thought is sounded okay, just wanted to hear what others get. I've searched here and google for optimal oil pressure and didn't find much.
I just put 5w30 synthetic in for my first oil change(43k) after buying this truck used a couple months ago. Seems like the pressure dropped a tad with the syn.
Old Jul 23, 2009 | 7:02 PM
broknindarkagain's Avatar
Your oil pressure shouldn't be affected between synthetic and conventional of the same weight.
Your pressure is actually really good. I get about 30 at idle and maybe 45 cruising...but I do have an older truck as well. You said you have a 5.3L, so I'm guessing that its newer right?
Old Jul 23, 2009 | 7:08 PM
tsduke's Avatar
2005 z71.
Old Jul 23, 2009 | 7:10 PM
yeah, you're running great oil pressure. you have nothing at all to worry about
Old Jul 23, 2009 | 9:57 PM
lukemoore646's Avatar
ha, your lucky, mine 93 only runs about 30 cruising speed and about 10 at low idle in drive, it has been like this scince i rebuilt the engine 40,000 miles ago, just have to run 15-40 in it and wait for it to let go, then comes the 327 tucked away in the basement, then comes the questions on the forum about puting an engine in a truck that is 30 yrs older than the one that was in it
Old Jul 23, 2009 | 11:07 PM
Mine runs real close to that until the engine warms up. once its warm, I get much better oil pressure.
Old Jul 23, 2009 | 11:39 PM
Blindsight's Avatar
I don't know if the fact that my engine is a big block 454 would affect the oil pressure, but at idle I get around 40/50, and cruising anywhere from 60 on up to 80. My truck takes 7 quarts of oil.
Steelman512
Jun 8, 2023 2:51 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
Dallas4
Oct 23, 2012 1:45 PM
trolea1234
Mar 3, 2009 10:58 AM
