91 chevy pickup motor trouble
Old Aug 4, 2009 | 10:48 PM
onecoldmini's Avatar
Default 91 chevy pickup motor trouble
I have a 91 chevy pick up truck with a 305 motor and the 700r transmission. the problem that i am haveing is that i am leaking oil out of the passanger side of the motor i cleaned the motor and and at idle it doesnt seem to leake but as soon as i go around the block it sprays all over the engine i almost think that it comes from the dip stick but not sure any suggestions thanks for ur time
Old Aug 5, 2009 | 11:13 AM
therewolf's Avatar
Clogged PCV will cause a top end oil control problem. How's the PCV valve? The breather?
Old Aug 5, 2009 | 11:27 PM
lukemoore646's Avatar
try a set of valve cover gaskets, they are cheap and easy to do and the stock rubber ones get eaten up over time
Old Aug 7, 2009 | 10:40 AM
therewolf's Avatar
I wouldn't worry too much about the valve cover gaskets at the moment. Bad PCV will blow out a fresh set of gaskets. Once the problem's been eliminated, you'll see less oil leaking at a lower pressure. THEN replace the gaskets...
mwl36m
1988 - 1998 (GMT400)
Feb 9, 2012 2:57 PM
Sparks134
Nov 6, 2010 5:05 PM
bhelp
Aug 3, 2010 9:05 AM
dozer157
Sep 8, 2009 7:32 PM
GMontag451
Sep 30, 2008 6:01 PM
