Nav Radio / Tech 2 programming issue...
Old Sep 16, 2009 | 8:23 AM
mirage00's Avatar
Default Nav Radio / Tech 2 programming issue...
Well I went to program my new Navigation radio (part# 20807044) installed on my 2009 burb and everything was going smoothly until I got to the equilizer section of the "RAD" programming section. The TIS2WEB provided me with two cal part numbers to choose from....
<TABLE id=tree cellSpacing=0 cellPadding=2 border=0><TBODY><TR><TD vAlign=top><TABLE><TBODY><TR><TD></TD><TD></TD><TD></TD></TR></TBODY></TABLE></TD><TD>15260987</TD></TR><TR><TD vAlign=top><TABLE><TBODY><TR><TD></TD><TD></TD><TD></TD></TR></TBODY></TABLE></TD><TD>15260988</TD></TR></TBODY></TABLE>
I couldn't select either one because the TIS2WEB software said my vehicle has a cal part number that is newer and not in this version of TIS2WEB. The cal part# 15260989. Then it said contact GM. I have a call into them but have heard nothing back. Shawn, any ideas?
Thanks
Old Sep 16, 2009 | 6:36 PM
I have never heard of this error.....ever....sorry bud, wait and see what GM has to say about it
Old Sep 16, 2009 | 9:50 PM
mirage00's Avatar
Just got an answer back today... they said to select Reprogram Replace ECU instead of the other option. I will give that a try.
Old Sep 17, 2009 | 3:19 PM
I've heard of issues when selecting just the Reprogram option. I have always used the Replace & reprogram option
Old Sep 20, 2009 | 11:18 PM
mirage00's Avatar
Well... I programmed everything I could for Navigation.... VCIM, BCM and RADIO.... STILL no traffic on my nav. GM must have either another module somewhere from traffic OR the head units on 2009's are different. I cannot understand this.
Old Sep 21, 2009 | 12:56 PM
could be a different Digital Radio Reciever. See the parts dept to see if there are 2 different options
Old Sep 21, 2009 | 2:04 PM
mirage00's Avatar
I thought about that... but the XM folkds said my current receiver was traffic capable already. They can tell by the RADIO ID.
Old Sep 21, 2009 | 8:23 PM
mirage00's Avatar
Well Shawn, you may be right! There are two digital receivers U2K and UBS... UBS is the receiver with traffic I have U2K. I just ordered the UBS receiver and will give that a try. Do you have access to install diagrams? Im wondering if there is a different or additional harness for the UBS receiver.
Old Sep 22, 2009 | 2:22 PM
Wiriing is identical between the two
Old Oct 19, 2009 | 10:48 AM
Jperry's Avatar
Where do you see the replace/reprogram option? Is this on the TIS? I am having problems programming my radio but don't remember seeing anything about the replace/reprogram option. It seems once we put the Vin number into the machine it came up with a set of cals where you pick the radio, audio, camera, etc and that was it. Is there something else I am missing here?
