Platform: J-body
ECM will not link to scanner 2000 Cavalier
Old Sep 18, 2009 | 12:32 PM
RYDREW55's Avatar
Default ECM will not link to scanner 2000 Cavalier
I just failed emmissions because the ecm will not communicate.
When I attach my scanner, it does not even light up.
Scanner works fine on my other cars.
I did see some suggestions to check the fuses. I will do that when I go home, but any other ideas to check tonight?
Thanks,
RYDREW55
Old Sep 18, 2009 | 6:09 PM
MDTAHOE's Avatar
Check fuses very very common. Does you cigarette lighter socket work? The data link connector shares that fuse in a lot of cars.
Old Sep 20, 2009 | 8:02 PM
moto's Avatar
check the cigarette lighter fuse! My Daughters 97 2.2 was the same way.
Old Nov 8, 2010 | 7:29 AM
jazzbass's Avatar
Default Scan Tool Not Linking
I recently prchased a 2001 cavalier for my son and it just came
up with a check engine light.
My scan tool was not getting power. Found the diagnostic link and
the cigarette lighter share a 20 amp fuse. replaced the fuse and it
immediately popped. I will look into this and report my findings on the short.
Old Nov 8, 2010 | 8:39 PM
MDTAHOE's Avatar
Disconnect the lighter socket then put the fuse it.
Old Nov 9, 2010 | 6:43 AM
jazzbass's Avatar
I put my test light across the terminals in place of the fuse
and had a short. Removed the cigarette lighter element and the trouble
cleared. If you wiggled the the element or put it in and out slowly
the trouble would come and go. Tossed the lighter element in
the garbage and problem solved.
I could now pull the code P0442 (small Evap leak)
Looked like the check valve in the gas cap was stuck. Lubed it and the
o-ring with a few drops of oil, reset the code and will see what happens.
MDTAHOE, Thanks for your help.
Old Nov 9, 2010 | 8:31 AM
moto's Avatar
My Daughters 97 fuse problem was blowing out to due a short in the horn in the steering column.
sleepingciv
Jul 25, 2020 1:03 PM
87camaro
Apr 16, 2020 1:55 AM
dukester544600
Oct 6, 2018 12:43 PM
redbone
Oct 16, 2009 11:16 AM
dukester544600
Jul 31, 2009 4:30 PM
