NEED HELP back pressure in my valve covers tons of white smoke in exhaust
Old Oct 15, 2009 | 3:52 PM
fishn4112's Avatar
Exclamation NEED HELP back pressure in my valve covers tons of white smoke in exhaust
i have back pressure building up in my valve covers that blows off my filler cap and pcv valve which is new and working there is also alot of smoke out the tailpipe and black carbon or oil dripping out the tailpipe 92 s10 blazer 4.3
Old Oct 15, 2009 | 4:38 PM
old dog's Avatar
Default pressure
not sure but sound's like you have a busted piston or rings pressurizing the crank case or the pcv system is not working .how much water in the exhaust and when ?pressure check the cooling system ,to rule out a blown head gasket .
Old Oct 15, 2009 | 5:58 PM
MDTAHOE's Avatar
Pull the hose off the other valve cover (opposite of PCV valve) see if it will suck a piece of paper against the valve cover. If it does not the pcv passages are blocked in the valve cover.
Philly
Jan 5, 2014 7:25 AM
454BBC
Apr 30, 2013 5:48 PM
Viperdude5064410
May 1, 2009 11:14 AM
rabbit0102030
11
Jun 6, 2008 7:11 AM
