98 Tahoe, Rear wiper removal
Old Aug 9, 2010 | 4:38 PM
Popeye's Avatar
Default 98 Tahoe, Rear wiper removal
i am trying to remove the "rear wiper arm" and have had no luck, is there a special latch to get this off. don't wanna pry it and break the plastic nut that holds the assembly against the window.
Anyone?
(98 tahoe)
Old Aug 9, 2010 | 9:07 PM
Assuming you're trying to remove the arm at the motor shaft, it's usually a nut under a flip-up cover.
Old Aug 9, 2010 | 9:16 PM
From the manual..
Remove or Disconnect
1. Washer hose
2. Lift the wiper arm assembly from the glass and pull the retaining latch
3. Wiper arm assembly from the wiper motor drive-shaft.
Silv1441
Mar 19, 2025 9:53 AM
ruley73
Sep 15, 2017 8:11 AM
Sardonic
Jan 27, 2012 4:01 PM
hossler
Jan 15, 2010 5:50 PM
97chevguy
May 24, 2007 2:35 PM
