left rear tire locks up on left turns
i have a 2003 chevy silverado 5.3L when i make left turns the back left tire seems to lock up or chatter. i have replaced the caliper brake pads i pulled the diff cover off and noticed nothin unusual i even removed the e-brake from tha side nothin seems to be workin anyone have any suggestions
Professional Mechanic
The differential may be going bad. Is it limited slip?Does you have the correct fluid in it? Did you put in the required limited slip additive if it is one?
Soules75
Silverado & Fullsize Pick-ups
November 30th, 2014 9:27 AM
rivero32
September 25th, 2012 12:48 PM
RomanGuzi
October 2nd, 2011 11:40 AM
jordan69s
10
June 1st, 2007 11:08 AM
