2007 tahoe turns and turns x4-6 then starts
Old Sep 22, 2012 | 6:42 PM
rivero32's Avatar
Default 2007 tahoe turns and turns x4-6 then starts
hello, I have a 2007 tahoe with apr 90,000 miles. never have had a problem until now, every single time we try to start it, it keeps turning over like it is going to start but it turns about 6 times and then starts. i have been told it might be my gas filter? anyone have any suggestions? before i take it to dealer...thank you
also no lights are on to indicate issues
Old Sep 22, 2012 | 7:25 PM
if when you shut it off and restart immmediatly and it starts ok...would rule fuel out for me. The fuel system is primed for the second start.
any codes set for camshaft position sensor? if that sensor is lost, it relies of crank sensor for spark and injector reference. It cranks longer as it takes longer for the ecm to recognize the position of number one cylinder.
Old Sep 25, 2012 | 12:26 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> rivero32,
I'm sorry you are experiencing this issue with your Tahoe. Please keep us posted of the results of your dealer.
If you have additional questions, please feel free to contact me privately.
Louis
GM Customer Service
Old Sep 25, 2012 | 12:48 PM
If you have to crank it that much, check the fuel pressure regulator. If that is good it is probably the check valve in the fuel pump assembly. My truck did that until I put an inline check valve in the fuel line. Solved my problem anyway.
ohioguy
May 24, 2021 8:26 AM
thisnthat
Nov 20, 2012 11:36 AM
bighoss
Jan 21, 2011 3:58 PM
snowonweb
Oct 25, 2008 3:42 PM
anchami
Apr 4, 2008 10:09 AM
