Notices
Sponsored by: DashLynx
1994 chevy 350 wont start
Old January 19th, 2015, 2:08 PM
chevykid1994's Avatar
Default 1994 chevy 350 wont start
Alright I need some help with my truck. I got it about 5 months ago as a project truck. Replaced engine and trans. Engine ran great before being pulled from parts truck. Got it in the other truck now and it wont start. Can spray starting fluid in tb and all it does is pop and backfire through tb. Need some help asap. Thanks in advance.
Old January 19th, 2015, 7:01 PM
burhead1's Avatar
Make sure the grounds around the thermostat housing are grounded. Make sure your crank sensor is connected. It sounds like the timing is out, you will have to crank to TDC and check under the distributor cap, make sure the rotor is close to number 1. Does not have to be dead on but close, when you do get it going you will need to do a crank relearn using a scanner.
Old January 20th, 2015, 12:39 PM
That was the exact problem. Got it running last night. But what do you mean by having to do a crank relearn?
Old January 20th, 2015, 10:44 PM
burhead1's Avatar
using a scanner it tells the computer the variation between your crank and cam, if not done can cause engine light to flash on hwy and poor fuel economy. Should be done any time cam, crank sensor, computer or engine is replaced.
streetterrorist
13
April 15th, 2022 1:42 PM
Kylewebb95
October 4th, 2014 1:20 AM
dnelly
May 6th, 2014 1:48 PM
00chevyk2500
January 1st, 2012 5:39 PM
dj alacran
May 24th, 2011 12:05 PM
Quick Reply: 1994 chevy 350 wont start
