Notices
Sponsored by: DashLynx
4l60e id
Old June 13th, 2012, 9:33 AM
gaftop1's Avatar
Cool 4l60e id
how do you tell a 93-94 c1500 4l60e from the rest.
thanx
Old June 14th, 2012, 4:59 PM
gaftop1's Avatar
Unhappy
anybody know?????
Old June 14th, 2012, 5:26 PM
RacerX's Avatar
there should be an tag on the case which identifies the date of assembly. I will have to get back to you to tell you what it is exactly.
Old June 16th, 2012, 4:00 PM
gaftop1's Avatar
Ok thanx
Old June 16th, 2012, 7:40 PM
RacerX's Avatar
Before 93s dont have electronic valve body so they have mechanical TV cable linkage. 93 & 94s dont have a lock up converter solenoid. but 94-to 96 have a plug in the case for the lock-up. Plus 95-up have auxilliary valve bodies and 96-ups dont have screw in SAE fittings in the case, they use NPT.
Old June 16th, 2012, 9:27 PM
gaftop1's Avatar
ok. i don't see any tags on mine.all i can see is m30 on the case.
i was having trouble with the shift from 1 to 2 and was getting a code 67 so i changed the shift solenoids and the lockup solenoid. didn't help anything but it did knock the code i was getting out.
since i have a lockout solenoid i guess that makes mine a 94-96 or am i wrong .
i'm trying to find a replacement but need to know whether i'm getting one that will work with my truck.
i found one and the tag says 3ckd on it and everything else looks the same.
thanx for the replies
abqgolfer
August 27th, 2011 11:30 PM
oppelousas
July 25th, 2007 1:46 PM
mixerpilot
July 4th, 2007 1:38 PM
rfishbone
June 26th, 2007 1:43 PM
dragondad
January 1st, 2007 3:27 AM
Quick Reply: 4l60e id
