Adding A Trailer Wire Harness
I just purchased a 2002 Silverado with no factory trailer harness. I would like to add trailer wiring. I only need the flat 4 wire. Am I able to buy a plug and play harness for this somewhere or is it more involved. My brake lights and turn signals are separate in back. Thanks for any help.
there should be a blunt cut wiring harness above/near the spare tire all ready for use. The wires will be in a black plastic loom. pull the wire out of the loom and you will see a white taped label that will describe what each wire is for. All you need to do is splice in your 4 pin connector.
I did this for my 2000 which did not have a trailer hitch; even the bumper hitch was unused. I picked up a class iv hitch at pick'n pull for $20 with the seven pin connector. If I ever what to run a brake controller, all I have to do is run one wire.
intheknow
July 24th, 2014 10:38 AM
latropa
April 17th, 2014 9:27 PM
leevil
Silverado & Fullsize Pick-ups
March 19th, 2014 6:44 AM
sswarin
10
April 1st, 2010 2:23 AM
d1nonly34
June 15th, 2009 10:38 AM
