Notices
Sponsored by: DashLynx
Codes P0171, and P0307
Old October 24th, 2012, 11:35 AM
jglidewell0708's Avatar
Default Codes P0171, and P0307
Hey guys, I am new to this site, and have been doing a little research. I have a 05 1500 with about 91K on it. My engine light recently came on and through up the codes P0171, and P0307 showing running lean, and a mis-fire in #7 cylinder. I read a few post in the past with same issues just haven't been able to find what helps get rid of the problem. I recently changed my plugs. That didn't help. So my next option would be the wires, then the coil. Should i change the coil first, or try the plugs? Or is there something else this issue could be? Any help or advice would be much appreciated.
Forgot to mention that my engine light starts blinking after i hit 30 mph.
Thanks, Jon
Old October 24th, 2012, 12:33 PM
kevinkpk's Avatar
I'd try injector cleaner
Old October 24th, 2012, 1:16 PM
Yeah tried that. also heard try replacing the fuel filter.
Old October 24th, 2012, 1:41 PM
kevinkpk's Avatar
Is it just that one cylinder? It is probably a bad injector. If it is just #7 to prove it's not a plug or wire swap them with another set, also with coil pack. If it continues with that cylinder it is the injector.
Old October 24th, 2012, 4:58 PM
Professional Mechanic
MDTAHOE's Avatar
Sounds like the injector is not firing on #7 thus the misfire and lean code for that side. It could be a bad injector or a bad connection at the injector. I have had to replace injector pigtails
Old October 25th, 2012, 9:53 AM
I planned on switching the coil and wire today and seeing if that still works. Thanks for the idea on the injector. Gives me a place to go for if the coil is good.
turfman650
December 28th, 2014 2:35 PM
ricardo1
October 4th, 2014 9:22 AM
phil11
January 27th, 2011 12:24 AM
03silverado
November 3rd, 2010 11:05 AM
PastorK
February 17th, 2010 9:31 PM
Quick Reply: Codes P0171, and P0307
